Hello! When I put my Bruin in reverse....reverse light comes on....and the quad backed up. I went forward, and everything was great. Then I tried reverse again, and the light would come on, but the engine would only rev up, it would not move. This has lasted for a couple weeks, then yesterday, when I started it - I tried reverse....and it moved, I moved it forward to try again, and then it refused to move again. I don't know much about these machines (Yamaha) but it seems like even though the reverse light comes on, something isn't telling the bike it's in gear....where should I start with this problem?
Sounds like a cable adjustment issue. There should be a reverse lockout safety cable which may need adjustment or replacement. Try pushing around the shifter a bit to see if reverse engages
Awesome! Thank you - I hope to dive into it today!
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Ethan7387
    • By mmikesell
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
