Anyone know what the fuse terminal marked UNSWITCH  does  .  Even with the key off it is causing a drain on my battery and I'm trying to figure out  what that terminal goes to.  It's a 10 amp fuse. If I pull it the "short" goes away.  Thanks in advance.
Hey @bodon , that unswitched fuse is a power feed that is constantly energized even with the key off.  It generally is on the fan circuit or a safety circuit,  so when the engine is hot and the cooling fan is running and you shut the engine off the fan will continue to run until engine/coolant is satisfactory. Wish I would have seen this sooner and answered to help you along.
The draw can be caused by a sensor that’s going bad, maybe a fan sensor.  It’s easy enough to isolate though.
    • By DPDISXR4Ti
      Thanks...
    • By bigd764
    • By disturbedmike244
      I have a 99 kodiak 400 4x4 that blows a fuse under the back left fender as soon as you attempt to put a new one in even with the key turned off. I'm having a hard time finding any wiring diagrams that show what this is for. And I'm trying not to have to tear into the wire harness. Any help would be appreciated.
    • By exalrod
      Hello All !
      I am looking for a service manual and wiring diagram for a 2005 50cc Polaris Predator 4 wheeler.
      Could anyone help with this?
