Need help with a 2007 polaris phoenix 200 no spark new cdi,new ignition coil,checked resistance on pulse coil and stator,not getting power to start button now guessing the solenoide went in all the testing not sure.also have three ground wires to battery is this normal or..?
Mine was a little older but my problem was in the throttle control on the handlebars. The rev limiter was soaking wet and killed the spark.  I separated the wires and she ran like a champ however sometimes the quad fired up and other times it had no spark at all during the troubleshooting process.
Double check your cdi is not wet or cracked in any way, moisture gets in and kills the spark.
    • By Tinkeringreg
    • By oxidized_black
    • By RussB
      Flywheel puller. Does anyone have the size as the part #529 036 049 is non existent
    • By Kawasakibayounospark
