Greetings
I have a 98 Polaris Magnum 425. Runs GREAT for 10 minutes then starts to load up (sounds rich) and looses power. Final;ly just stalls out on idle. If it sits 20 minutes will run again.
replaced fuel, added fuel treatment (seafoam), Replaced plug (carbon fouled), plug wires, air and fuel filter, checked all fuel and vac hoses, REPLACED carb with new. Still no good. Just ordered a coil, not sure if that will help
Note: both the new and old carb only had the idel adjuster screw - cant find the jet adjustments or air/fuel mix screws so I cannot say how they are set.
Looking for ideas short of spending big $$ on Polaris service
HELP?????
Dan
Just a thought check your fuel cap. Because it runs good to start it sounds like the cap might not be venting. I maybe way off but I've ran into this before. Mine wasn't actually the cap but the vent hose attached to it. Hope that it helps you. Also welcome!
is this a 2 stroke model or is it a 4 stroke?  if 4, try checking compression and also the fuel cap like @WILYUMS mentioned.  other than that, you seemed to have covered all the bases.
could also be electrical like @Frank Angerano mentioned..
but i always start by Checking things rather than focusing on what seems to be the issue and replacing that part.
same problem with or without fuel cap, rectifier is not hot
Changed the oil as someone in another felt fuel vapor in oil could be culptir - still no good
Also noticed that I am only getting half throttle - if that
What do you mean half throttle ?
Pull the spark plug and see what color it is and put a new one in while ur at it.
if its super black it's obviously running rich and it could be the rev limiter.   98 goes back a little ways so I'm not sure but look on the throttle control on the handlebars  and see if there are wires going into it.
    • By oxidized_black
    • By DPDISXR4Ti
      Thanks...
    • By Sportsman500guy
    • By colin james
      View File 2005 Polaris Phoenix 200 service manual
      This is the service manual  for the polaris phoenix 200 down load all chapters to have completed manual
      Submitter colin james Submitted 07/19/2018 Category Polaris ATV
