the main thing is to make sure the tie rods are the same length and the tie rod end bolts are the same diameter.  you might be able to order a tie rod and use just the tie rod end off the new one if the sleeve is too long or short for your quad.  just make sure your looking at the same diameter threads for everything
    • By Trent Finnessey
    • By Mhatayas
    • By Dumass
    • By Arizona
