i use a big set of channel locks and twist the shock adjustment colors.  as for the setting- whatever suits you best👍  you can also use the proper adjustment tool but i didnt feel like paying for one lol
    • By Sportsman500guy
    • By alain
      I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
      Any one would havd answers would be appreciated. Thanks
    • By waybel
      Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
    • By Jacksonbell
      I just went out to start my 2004 polaris sportsman 600 and nothing happened. It didnt have power to the dash and wouldn't turn over. I have no idea why, but it's not the battery because the winch still works. Can anyone help?
    • By Malta54
      I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
      Sparking Plug
      Fuel Injector
      Fuel Pump
      Fuel Filter
      Fuel Valve
      Fuel lines
      Power Control Module
      The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
      The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
      Would greatly appreciate any assistance.
      Thanks in advance.
