Unfortunately this weekend we waived goodbye to the 99 400ex.  Ported and polished head, DMC Alien exhaust with dual header, an absolute unit that would run 70 on the top end.  Fortunately though the 400ex left in exchange for a fairly cherry 98 Honda 300..the holy grail of reliability in a mud and water toy.  Previous owner added the snorkels and it was a decent job.  Put some 25" swamp witches on it, now it just needs 1" spacers, 2" bracket lift, couple of pinion seals and a pound or two of dielectric grease.  Hate to let the 400ex go as it was a gem, but it's hard to pass on a cherry 300.  These things are just so dang reliable and easy to work on.
Nice Honda 300 !! Im a 400ex guy though !!
2 hours ago, Frank Angerano said:
Very nice find. $ ?
Even swap for the 400ex. Pretty close in value, NADA has the 400ex a bit above but in the south sport quads are hard to move and 4x4 ESPECIALLY a 300 are way WAY overpriced. Real money in it is about $800 since that was what was in the 400ex. The 300 would bring closer to $1500 here if it were for sale.
Looks good. I see the oem head lights have been replaced with aftermarket led and the fender flares are gone. The snorkel looks good and everything else looks in tact but it was definitely in the hands of someone who was able to work on a quad or at least tried.
Here's the thing about snorkels that I don't get.  Folks usually put an upright snorkel 3 feet in the air; that's great, but that would mean water was over your head.  snorkels are best left just under chin height sitting on the seat.  Any taller than that and it's just a "mine is bigger than yours" situation.
This bike seems to be completely untouched.  The carb is absolutely disgustingly dirty and I see that as a good sign.  It's not been taken off to clean!
Yea that snorkel is over kill !! LOL wonder if the airbox is water tight !! I wish deals like that would come my way !!
And the new toy in the shop is already wounded.  Something got in a bind and blew the whole chunk of case out around the primary drive gear at the back of the motor.  In the pic you can see the crack along the top...there is a big chunk missing from the bottom.  And it won't roll....but the front and rear diffs both seem fine.  Unfortunate.  This looks to be a bit of a project.  Still feels like it will shift through gears so i'm wondering if the ring and pinion just jumped a bit and blew something to pieces.
Separate cover. Another group I'm in said it's not completely unusual on the bike as sometimes the ujoint explodes and takes the primary gear with it. Hoping I can lay it on the side and slide the broken one out and new one in. Alternative is splitting the case.
Easy @Frank Angerano, the other group mentioned is a Honda 300 facebook group...I'm a member of no other quad forums...quite honestly there's not another one I've found that's as good.  The TRX forum is good but I work on a lot more than Honda. I updated the new thread i created for this issue but I'm reading it's likely the ujoint in the axle tube grenaded and when it did it took out the primary drive housing.  Pretty common from what I've read.
There's not too much to look at other than the carnage of the primary output gear.  You can pull the clutch packs, take 3 bolts out and slide the gear out of the case.  The trick is going to be not letting the trans gears fall into the bottom of the case!  Think i'm going to lay the bike on it's side and then chase the output shaft through from the clutch side with a similar sized pipe of some type.  In theory, I can just slide the replacement back through, stick the clutches back on and be good to go.
  • 6 months later...
This 300 is now gone on to the next owner.  Ended up trading it with a couple bucks for a 2013 420.  The 420 has gone through some changes too with reworking the snorkel, winch, etc.  So far the 420 has been pretty solid.  My other 300 is in another thread.
  • 2 years later...
    • By Trent Finnessey
    • By Dumass
    • Guest
      By Guest
      I have a 2022/23 Honda Rubicon, and was wondering if there is an exhaust deflector available.  I have a rear basket w/ chainsaw mounts, a winch on the rear, and a hitch.  When I am working at the rear of the quad, the exhaust puffs and hits us, while we work.  It is quite annoying and wound like to be able to direct the exhaust downward.  Is there anything that you know of that would work w/o creating any back pressure that might disrupt the engine?  I’ve been searching for something like this, but can only find ones for small engines and silencers that would interfere with the winch.
      dave
      For ATV and UTV enthusiasts, regular maintenance is key to ensuring the longevity and performance of your vehicle. One of the most overlooked yet essential components is the battery. Just like in cars, ATVs and UTVs require a reliable power source to start the engine and power additional features like lights, winches, and electronic accessories. Understanding why changing your ATV and UTV battery at the right time is essential—and why Weize batteries are a top choice—can keep you out on the trails longer and reduce the risk of unexpected battery failures.
      Why Changing Your ATV/UTV battery is Crucial
      1. Prevent Unexpected Breakdowns
      Imagine being out in the wilderness, far from help, and suddenly your ATV won’t start. A reliable battery ensures that your vehicle can always start up, keeping you safe and ready for any situation. Old or degraded batteries lose their capacity to hold a charge, increasing the likelihood of sudden, inconvenient breakdowns.
      2. Improve Overall Performance
      A fresh battery doesn’t just guarantee startup; it also supports optimal performance. ATV and UTV batteries power important accessories, such as headlights, which are crucial for visibility in low-light conditions. A weak battery can dim your lights, affect the functioning of electric winches, and even disrupt GPS or other electronic equipment. A new, high-quality battery helps maintain the consistent power output necessary for these essential features.
      3. Extend the Life of Other Components
      An aging battery can strain other vehicle components. As the battery weakens, it requires more effort from the alternator and other electrical parts to maintain a charge. This added stress can wear down the electrical system over time. Replacing the battery on schedule can help to reduce strain on the alternator and prevent more costly repairs down the line.
      4. Adapt to Changing Seasons
      Temperature fluctuations can significantly impact battery life. Colder temperatures reduce battery efficiency, which can lead to issues during winter months, while extreme heat can cause rapid battery degradation. Changing your battery seasonally or before long periods of extreme weather can help avoid seasonal breakdowns and extend battery life.
      Why Choose Weize batteries for Your ATV or UTV?
      When it comes to replacement batteries, Weize is a top choice among ATV and UTV enthusiasts. Here’s why Weize batteries are particularly suitable for powering these rugged vehicles:
      1. Exceptional Durability
      Weize batteries are designed to withstand tough conditions, including off-road terrain, shock, and vibration. Whether you’re tackling rocky trails, mud, or hills, Weize batteries are built to last. Their rugged construction helps to ensure reliable performance even under the most challenging conditions.
      2. Long-Lasting Power
      Weize batteries use high-quality materials that allow for a stable charge and dependable discharge rate. This long-lasting power translates into fewer replacements, saving you money over the long run. Weize batteries are built to provide reliable starting power and can handle additional loads from accessories, ensuring that your ATV or UTV gets all the energy it needs.
      3. Low Maintenance and Easy Installation
      Weize batteries are designed with a focus on low maintenance and easy installation. Many models come pre-charged and sealed, meaning they’re ready to use right out of the box. This ease of installation makes them an ideal choice for riders who prefer a straightforward setup with minimal hassle.
      4. Affordability and Value
      Weize offers high-quality batteries at competitive prices, making them a great value for ATV and UTV owners. Despite their affordability, they don’t compromise on durability or performance, providing excellent quality without the premium price tag.
      5. Environmentally Responsible
      Weize prioritizes sustainable manufacturing practices, ensuring that their batteries meet environmental standards. This focus on eco-friendly production is a plus for ATV and UTV riders who want to reduce their impact on the environment while still enjoying high-quality equipment.
      Signs It’s Time to Change Your battery
      To maximize your ATV or UTV’s performance, be aware of the signs indicating that a battery replacement is necessary:
      Slow Engine Crank: If your engine takes longer than usual to start, it may be due to a weakening battery. Dim Lights: Dimming headlights are often a clear sign that your battery is losing its capacity to hold a charge. Frequent Recharging: If you find yourself recharging the battery frequently, it might be time for a new one. Age of the Battery: Most ATV and UTV batteries last between two to four years. Regular replacements can prevent unexpected breakdowns. Final Thoughts
      Changing your ATV or UTV battery when it shows signs of wear is essential for reliable performance and safety on every ride. Choosing a dependable brand like Weize ensures that you’re investing in long-lasting power, durability, and value. With a new Weize battery, your ATV or UTV will be ready for every adventure—whether you’re out on the trail or tackling heavy-duty tasks. So before you embark on your next journey, make sure your battery is up to the challenge, and consider Weize as a trusted choice for dependable power.
