12 hours ago, mikeexplorer said:
Nice video, winter here has been terrible. Ski slopes are not that good right now. The snow in the trees is from snowmaking, They only got a few hours in before it warmed up.
Thanks Mikeexplorer Guy ... glad you enjoyed the video and I THANK YOU for watch'in too !!! :notworthy:
Man, that photo is sad for sure. However, we have soon, just not the amounts we should have. Here's hoping you get some soon so the skiing isn't on dirt & rocks !!
@mikeexplorer hopefully today you got some!
@Gunny Great video as usual! Do you ever see any wildlife? That's a lot of snow...some of those snow drifts are insane! Feel like I'm riding when watching, pretty cool. Just need a VR headset and I can ride on a quad with tracks vicariously through you!
Thanks Ajmboy, glad you enjoyed the video. Yeah, I see wildlife sometimes. However, most of the time it's on the drive up to the parking lot or the drive going back home. And if I do see any out on the snow, by the time I can dig my camera out, they're gone.
Yes, it is a lot of snow, but there should be more. Anyway, that's what I think, but it's still early in the season ... so ... PRAY FOR SNOW !!! I agree, I love that drift area & try to get up there as often as I can to see them & see how they've changed.
Well alrighty, glad you enjoy the "Ride-A-Long" ... :twitsy: ... And THANKS for watch'in too !!!  :notworthy:
Edited by Gunny
2 minutes ago, quadnut20 said:
Sweet !! as usual gunny !!
Why Thank You Quadnut ... THANK YOU VERY MUCH !!! :notworthy::notworthy:
Glad you enjoyed the video and I Thank You again for watch'in it !!!  :yes:
    • By qcm413
      Hi,
      thank in advance
    • By DaveswMN
      Thanks for any thoughts.
    • By mkay1911
      HI all, new guy from upstate SC here.  I own a 2006 Big Bear 400 and a 2007 Grizzly 350.  Mainly here for tech.
    • By DayBreakJim
      20230725_171507.mp4
    • By Indiana-George
      I bought a Suzuki quadsport lt230s in rough shape. I've been slowly buying parts to restore it it's former glory. (Motor has good compression, so I took that as a green light.)
      My question: The tires don't keep air. Before I pull the trigger on new ones, I'm wondering how to get them off so I can attempt to reseal the beads. Any recommendations on how to get them off?
