So I picked up this quad for 200 bucks. Needs everything serviced or replaced due to neglecting. So I tore into it and stripped it to the frame and did a bunch of work. I’m having an issue. It runs and revs to 3/4 throttle and almost bogs out. It smokes a lot at wot. So the 210 jet is responsible for that. I know it’s a 2 stroke carb and I just don’t know what to jet with. The oil injection is faulty so I disconnected it and run 32:1 mixed. Any ideas fellas?
Merry Christmas and happy new year frank!
I disconnected it from the intake boot. Put a bolt thru the intake to cap off the line. Then I kinked both the lines from the pump and tank so nothing got in there. The tank is empty except for the little bit that’s left.
Im going to try a 175 main and leave the needle alone. If anything I may change the needle to a cel or yym. Depending on throttle response
I would definitely change the jet. Reason i was asking about the oil intake was because if left the oil intake port open you would have some suction drawing air through that port but i know you better then that.
Did this problem just start happening?
Yeah. Out of no where. That 175 was worse than before with the 210. I’m gonna try 240 230 and 220. It’s dialed in right. Runs great. Just not at wot
Okay. So 210 220 230 and 240 are all the same. The 175 loads up and bogs but if ya feather into it,
stumbles. If ya juice it it will bog but clear out and rev like a beast. I’m thinking a spark delivery is the culprit. I just don’t want to lean it so hard I melt rings.
I bet the flywheel has something to do with it. The coil is new and the plug. Reeds and intake boot. The carb is clean and no engine leaks. Compression is a solid 148 and holds.
I hear your point on possibly the flywheel and the trigger coil maybe having a problem.  Its possible that the gap is causing a problem  and at high rpms its breaking down?   Maybe put an inline spark monitor so you can see if its in fact breaking down at the high rpm.
If its breaking up at wot it makes me think its the reeds.  I know you changed them but maybe the reed retainer plates are not right?
Why I'm thinking along these lines is the high rpm problems.  During the intake period at high rpms the velocity and intake at the  reeds could  be problematic causing a fuel delivery problem?
Im just throwing some possibilities out there maybe you will stumble onto something.
Is there a difference in reed plates? I know branding is different. I.E. Boyseen fmf oem. But the only difference I see is the dual stage reeds vs regular. What I really need is a multi tool to check the every thing. Kinda like a amp probe or a clamp on voltage meter. I know Klein makes them. But are they optimal for 12 volts or less?
Klien makes a good one that goes low. I will send you a pic of mine. Have you put any thought into the in line ignition tester to see if your losing spark at any certain rpm?
The reed plates are different depending on the brand and  power band of the engine. What's in there now ? I know you checked and changed but i would have a second look at that and make sure that the plates are ok.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Dumass
    • By fwsamm
    • By colin james
      View File 2005 Polaris Phoenix 200 service manual
      This is the service manual  for the polaris phoenix 200 down load all chapters to have completed manual
      Submitter colin james Submitted 07/19/2018 Category Polaris ATV
