Hey guys, need some help with my 2016 Yamaha Kodiak 700 4x4.  Was riding and it started smoking below the air box and then Caught fire.  We got the fire put out quickly with a fire extinguisher.  Many of the wires below the air box got damaged.   I purchased a new wiring harness for the atv and replaced that as well as any other damaged cables or parts that burned up where the fire was.  I also replaced the regulator, the ECU, and the starter solenoid. I also replaced the stater since some of the cables that went to the regulator were damaged.  It acts like it will crank but it won’t turn over.   The fuel pump initialized when I turn the key so it’s working.  I’ve spend $1500 on parts and no luck yet.  Any suggestions?
    • By Tim Keiper
    • By fwsamm
