Hi, I’m a 16 year old that is wanting to get more into vehicle and mechanic repair. My dad has an old ‘96 Timberwolf that he doesn’t remember running since I was born. I want to get it running again as a memory for him and to help us be able to hunt together, and of course so I can learn how engines work more than the little information I know now. I’ve pulled the carburetor and gas tank off of it, and the carburetor is getting cleaned by a friend. I can post photos of the condition it’s in later, I’m just curious where I should start in my journey to get it running again. The power switch is broken off of the handlebar, so I am looking into fixing it, along with the pull cord. I’m afraid the engine is seized up, and I’m curious to hear any input anyone has. Thank you all.
Edited by Chris Chitwood
Title correction
Sounds like a nice project! Once you get that carb back you want to be able to crank the engine, ideally with the starter. So you’ll need to fix/replace the switch that’s broken. How’s the battery? May need a new one if it’s the original. Once you get it to crank, you can go from there.
@Ajmboy Hopefully, if all goes as planned I will have the carb back around New Year, cleaned and ready to use. I’ll have to replace the starter switch, which I’ve researched and found a good price on. I’m not sure how old the battery is, but I can check tomorrow, I’ll probably replace it just to be sure I have a good one. I have one question though. I tried to initially start it with the pull cord, but when I tried the cord went slack and won’t pull back into the spool. I tried to take the screw/bolts out of the cover to remove it and try to fix the cord, but they were previously stripped. How should I go about pulling the cover off in order to fix the cord? Should I just cut a slit in it with a dremel, remove the screw, and find replacements? Thank you for your help.
Hey @Chris Chitwood welcome to Quadcrazy.
Nice atv you got there. If the screws or bolts are exposed enough on the pull starter you might be able to grab them with a visegrip pliers.  But before you do that see if you can spray the inside with WD-40 utilizing the small red tube on the tip to get inside the pull starter and spray it good and let it sit.
If the recoil spring is broke then it will need to be replaced but it just may be rusted inside.
@Frank Angerano thank you for your advice. I sprayed the WD-40 like you said earlier in the day, and I just tried to get the cord to retract. I haven’t had any luck. I tried to use vice grips on the screws, but there isn’t enough room between the cover and the screw to do any work. I also tried to slit the head of the screw and use a screwdriver to remove it, but the metal is too soft and I still can’t get it loose. I am questioning whether I should cut the head off of the screw and use vice grips after removing to cover to remove the rest of the screw. I would appreciate any other ideas you have.
Can you post a few pics of the screws. Im sure between me and the rest of the gang here a solution will come up.  My worry is if you cut the screw heads off you will only be left with a 1/16" of an inch of screw left to try and grab.
BD38418C-268F-4733-8B8B-0A7F7FFE343E.thumb.jpeg.602f933712771f67a21d3ef99d7dcaae.jpeg704646A1-8773-44D1-AF86-ABC4905E2924.thumb.jpeg.fd55f28f16f6a1e7ea39ac2321421062.jpeg
Here are pictures of two of the screws. All of them are stripped, except for the one I was lucky enough to remove. Hopefully, you can see the slot in the picture. I tried removing it with a screwdriver, but the metal was too soft. Hopefully y’all have better ideas than I have had so far. Thank you.
Sorry for taking so long to respond, I just got back in town from a vacation. I have tried both a small and large set of vice grips, but I haven’t had any luck on the screws that I can reach with them. The metal is so soft that it just peels away or bends under the pressure of the vice grips.
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By carkivey3
