2008 Suzuki Kingquad 450AXI Issue
By BuckBilly
By P_syko
By TimothyLindblom
Hey all, I just picked up this Massimo UTV for $500. Got it home and replaced the starter solenoid which successfully got power to the starter. Starter spun but engine didn't turn over although the engine is not locked up. I thought it was a bad starter. Got a new starter put on today and it does the same thing. Pulled the clutch cover and saw the engine is trying to turn over but something is slipping and not letting it turn over. I figured it must be the gear on the engine that the starter turns. Where can I get that and can it be replaced without pulling the motor? And am I correct that that's the issue?
Thanks!
Short video attached below
