    • By Cramer88
      out of the blue my vinson wouldn't shift into park and when I am in H or L and go past a slow pace (maybe in 2nd gear) it grinds and Low grinds even louder. It sounds as though it may be in the rear diff. I have not tore into the rear end or anything yet. I was looking for advice before tearing it apart. Reverse has no grinding at all and H gear doesn't grind until you get moving past a walking pace. L grinds as soon as it moves. It shifts into gear smoothly and 4wd works just fine. There was no issues leading up to this. Any advice is appreciated thanks.
    • By Gary Skriba
      just got a 99 Kawasaki bayou replace the coil because the spark was very weak still have the same issue before it would start after a while that it would start everyday as long as you started it every day but if you let it set you play hell starting it looking for information on what could possibly be wrong maybe the CDI box not sure any help would greatly be appreciated thank you
      When it comes to adding more power to your ATV, the first thing that usually comes to mind is bolting on a slip-on exhaust. However, that usually means you are also bolting on a lot more noise. HMF do...
      More...
    • By CJ River Rider
      Anybody know whatever happened to this?
      ride Where to ride ATVs and UTVs
      Utah is one of the best states for riding ATVs and UTVs and Sand Hollow State park OHV Area is one of the best OHV riding areas in Utah. View the full article
