1992 yamaha timberwolf Electrical Issue
By kawasig
By TimothyLindblom
Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
Any ideas on what it could actually be?
Timothy
By DaleJAM
By gwares
Price : 4500 EUR
The Kymco CV3 is a pioneering three-wheeled maxi-scooter that combines the agility of a motorcycle with the stability of a trike, catering to riders seeking versatility and performance. This can be ridden on a car license!
Key Specifications:
Engine: 550.4 cc parallel-twin, liquid-cooled
Power: 51 bhp (38.1 kW)
Transmission: Continuously Variable Transmission (CVT)
Fuel Tank Capacity: 15.5 litres
Seat Height: 795 mm
Dry Weight: Approximately 280 kg
Brakes: Dual front discs and single rear disc, equipped with ABS
Suspension: Independent front suspension with dual leaning wheels; rear mono-shock
Wheels: Front: 13-inch; Rear: 15-inch
Everything works and new!
We try to capture everything in photos for you.
If you have any questions or need other photos, just ask, thanks.
Send a direct message to make an inquiry or text:
WhatsApp: +33 758 56 21 59
