Just picked this up at a yard sale, runs and drives..color coded wires for battery were backwards, Meaning a red wire was used for negative and a black for positive....
Upon bringing it home decided to boost the battery and walked away giving it a small charge prior to starting it..came back to find battery slightly smoking and my Green light for power (neutral) was no longer lit up...Still starts when i pull start it with key on.
Turn key on and no starter spin up, no lights
Id like to get my Electric start working, What could be the problem, Where does one start.
Is it possible you put the charging leads on the wrong terminals on the battery ? Smoking battery and your explanation of what the bike is doing sounds like a battery either installed the wrong way or the charging clamps put on the wrong place.
I would check your main fuse next to the starter solenoid.  If that’s ok I would start looking for burnt wires.
Once I noticed the backward battery leads I would have corrected that situation ASAP and tried to figure out why! So look into that first and  go from there would be my take.
    • By killerklown
      What is the blue wire at taillight?
    • By TimothyLindblom
      Timothy
    • By DaleJAM
    • By gwares
      Price : 4500 EUR
      The Kymco CV3 is a pioneering three-wheeled maxi-scooter that combines the agility of a motorcycle with the stability of a trike, catering to riders seeking versatility and performance. This can be ridden on a car license!
      Key Specifications:
      Engine: 550.4 cc parallel-twin, liquid-cooled
      Power: 51 bhp (38.1 kW)
      Transmission: Continuously Variable Transmission (CVT)
      Fuel Tank Capacity: 15.5 litres
      Seat Height: 795 mm
      Dry Weight: Approximately 280 kg
      Brakes: Dual front discs and single rear disc, equipped with ABS
      Suspension: Independent front suspension with dual leaning wheels; rear mono-shock
      Wheels: Front: 13-inch; Rear: 15-inch
      Everything works and new!
      We try to capture everything in photos for you.
      If you have any questions or need other photos, just ask, thanks.
      Send a direct message to make an inquiry or text:
      WhatsApp: +33 758 56 21 59
