Hi all new to the forum I have a Yamaha Moto 4 champ (100cc?) (YFM100) so I've been trying to get this thing to start for awhile honestly I'm running out of ideas so I'll start with the things Ive replaced and done first it was not trying at all and then I put a brand new battery then the terminals broke so I bought some nice copper ones fixed that up so now battery is got good voltage and all that I have checked all the plugs cleaned everything off so anyway it still wasn't trying but I couldn't get the crank case off and I didn't think using fire was a good idea lol so I busted the crank case off on the left side(if you are sitting on it) wierdly enough the flywheel started spinning I thought it was odd but went with it then I replaced the spark plug still wasn't getting spark so I replaced the ignition coil then it was getting spark next the carburetor was really gross I cleaned it out still wasn't working so I in turn decided just to replace it with a new one so I did (PS I never figured out how the fuel lines hook up if someone wants to help with that to lol) also for good measure put a new air filter so then I pressing the button Everytime I replace something and nothing so then I think what if it's the stator so I have no idea what a good or bad stator looks like but me being to rough I broke the wires on the thing but still no changes the fly wheel spins gets compression (I think) getting spark from spark plug idk other tidbits that might be useful I don't have a clutch line so idk if that has something to do with it I do have the break zip tied in to bypass the safety feature also the throttle cable is in fact broken and I'm working on buying a new petcock for my gas tank because my current one is broke I have very limited money this is supposed to be a project before I go to school for welding and automotive tech so I don't have any money to get a mechanic lol but I'm pretty confident in my ability to do anything u suggest any suggestions are welcome I'll edit and submit pics
Welcome to Quadcrazy @Elijah Stone  Thats some write up.
Once you replaced the ignition coil and you had spark the stator should be left alone since the spark is there.
The fuel lines are not difficult to put on, there should only be one fuel line on the left side of the carburetor and the others would be a vent hose that may run up behind the gas tank and another hose would be connected to the bottom of the bowl on the carburetor and do noting but hang down under the frame. It’s called an overflow hose  that allows fuel to spill out of in the event the carburetor had a failure of some sort or the bike is flipped over.  Both hoses would be generally smaller then the fuel hose.
So what I would do is for now turn the gas off. Pull the spark plug out and test for spark.  Take the spark plug and plug it back into the ignition coil wire and rest the metal part of the spark plug on he engine head. Make sure your kill switch is on and crank the motor. You should see a spark at the plug right at the gap. Make sure it’s plugged in good and touching the metal part of the engine.
If you have spark that’s great, put the spark plug back in and then make sure your fuel lines are properly connected and discussed. If your not sure then post some pics and we will help you along. If you figured it out then turn on the fuel and crank the engine. The bike should fire up just make sure your choke is working properly.
Unfortunately these things cost money to fix so your going to have to spend a little money if you want to get it back to good.
Let us know how it goes.
Good luck  at welding and automotive tech  school. Your going to enjoy it, stay focused and learn as much as you can!
This will be a fun little project to work on for you as well as learning a lot about the atv world just be careful.
@Frank AngeranoThank you so much for the reply I do in fact have spark I'm not home rn but when I do get home I will post pics of the fuel lines I just replaced my petcock valve on the gas tank because it was corroded and green and had none of the little things that go into the gas tank I forgot to mention though that my headlight and neutral light will not come on the headlight used to work but now it doesn't so I did replace my Glass fuse holder coming off the postive terminal on the battery with a new one stupid me though didn't check the voltage to make sure the fuses where the same so I'm thinking that might be why my neutral and headlight arnt working but my starter does kick on so idk? Anyway when I get home I will post pics of the fuel lines
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Frank Angerano
    • By Tinkeringreg
