So the saga with the quad continues, for those who dont know I have a 1997 yamaha warrior that is a project quad. Me and my man are takin it apart and redoin stuff. The steering bearing retainer is locked on and we cant get the old bearing out, we have again tried everything from lubing , heat, cranking on it, to breakin a socket wrench tryin to get this thing off. Normally these nuts are supposed to be easy, any one have ne other suggestions on what to try???:aargh:
Not sure how it is on other quads, on Yamahas, the bearing drops in and then you thread a retaining nut into the shaft, the shaft is threaded. It is real low torque and comes out with a 29mm Allen wrench. Then the bearing will pull right out of the top.
The issue is the retaining nut has snapped a 1/2" Ratchet which had a 4' breaker bar on it. This sucker is in there. Heating it to red hot then muscling it may just bend the bracket and not break it free.
ha yeah what my honey said :yes:
won't be able to snap pics till later. I just brought it to a garage that the company I work for owns and I put 600lbs worth of impact power on it. Didn't budge. Went both ways.
They didn't have the time to put the torch to it. My little propane torch doesn't heat it enough I think.
We actually bought some gaskette remover stuff today. We heard on another forum that its worth a try to get that bolt out. That stuff takes rust off like you woudnt believe. We are soaking it in pb blaster tonight and then the gaskette stuff tomorrow night and we will try to pull it again after soaking it. My honey broke a breaker bar tonight thathe just bought tryin to get the damn thing off. :aargh::aargh::aargh::aargh::aargh::aargh::aargh:
  • 9 months later...
