My scrap heap rescue '87 LT4WD has been running great until a couple days ago when the electric start started clicking instead of starting. Click is coming from the front so I got a new solenoid to try that (battery is showing 12.9 volts and is almost new so I doubt its battery). But like an idiot I pulled off the old wires without even noting what goes where.
Now the battery cables I know, it lines up with the battery terminals. + on the right, ground on the  left if you're looking at the solenoid. But as for the the smaller wires that run to the starter switch, i have no clue. Help!
Call off the search. Yellow/black matches up with +  and Black/white with ground side. (Duh.) Also, the new solenoid didn't fix it but cleaning the wire terminals on the starter did. Live and learn.
    • By Tinkeringreg
    • By kaidella
    • By jhamrick75
    • By JMSwed
      Hi EVERYONE
      New member here
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
