New Videos
By BuckBilly
By Chucksta
Any ideas?
By QuadDad22
Picked up a 86’ LT 185 for $10 in trade value(my items only cost me $10)
recoil only , I pull the recoil and it won’t move , so I took it off , I can spin the crank there one full turn left then it locks up , and one full turn back to the right and it locks up
pulled the plug , the piston is moving up n down , both valves are moving(pulled the caps)
pulled the clutch off , oil pump gear , and it still locks up after one turn
any ideas or where to go from here would be greatly appreciated
im a 2 stroke guy so this all is new to me
thank you in advance y’all
By Spritee1
having an issue with the unit when running under a load up a hill or in high gear, seems like the belt is slipping, there is a clapping sound coming from the primary clutch like it releases and snaps back in. i don't think I should have a noise like that. this is a friends unit and he has already replaced the primary twice with the same result.
not sure where to look next
By hardcastle
