  • 5 years later...
  • Ajmboy unpinned this topic
      CARFAX https://www.carfax.com
    • By robert63
      my cat only has 100miles on it and is in mint cond. since i bought it new in 2009 it has had what i believe to b a carb problem. going down a steep hill makes it want to stall. as soon as u r on level ground its fine.and at top speed it kinda acts like its starving for gas. u let off the throtel a bit n its fine. idels good starts good. hav taken it back to dealer several times. they eithor said it didnt do it or mayb bad gas. my friend says it sounds like the float level isnt rite. any advise would realy help.
    • By DonB
      Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator.  Must I spend the $750+ for a new assembly from Arctic Cat?!?  Here's what I've tried so far.
      Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists.  I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly.  When I can temporarily get the PSI right, everything works great.  Anyone else ever dealt with this problem, and, if so how did you fix it?  Perhaps I should adapt the fuel system to include a gas tank return line?
      Any insights are greatly appreciated, Don
    • By vickijjones
      Just purchased this 4 wheeler in June, now I need to replace 1 wheel bearing, 2 boots (on rear), figure just do both sides bearing & boots. Was told it had 2" lift kit on it.Read some where might need to get different boots since lift. Want to do upper & lower. Any suggestions on how to tell if it's lifted & boots I need?
    • By alexwv1863
      I'm looking for a repair manual that's specifically for a 2016 Arctic Cat 500. I have looked in the downloads section and there's one but it's for 500,700 & 1000 models. When looking through it, things I'm trying to find to fix on my 500 is not specific for just that model, and it's geared more towards the 700 model. So, needless to say, it really isn't helping me. I really hope someone out there has one. Thanks.
