I have access to a an aerospace welding company that owes me some favors. They even have laser welding capabilities. Here is a picture of what the inside looks like. You can see its really blown out. Do you guys think if i have that completely welded in and machined it back to where it should be. That it would hold, or should I try looking for a replacement. Haven't had luck on a decent looking one.
Edited by Christopher Middleton
I don’t think that’s going to work out on a weld.   I would look for a new casing.  It’s just so far worn even if you had it repaired finding the center point of the hole would be a tough one.   And if it’s not perfectly centered then it’s going to wear and tear again.
I hear you about that. All the ones i come across all have cracks abd pretty beat up for the price. I think im going to try and put it up on my machine tomorrow and try to map this out. I should be able to get it close by a couple thousands. (0.001) of where it needs to be. If i have enough pull at my work I might be able to get them to 3d scan it but not sure.
    • By Ethan7387
    • By marcosphoto
    • By Randel1
    • By Coyote251
    • By exalrod
      Hello All !
      I am looking for a service manual and wiring diagram for a 2005 50cc Polaris Predator 4 wheeler.
      Could anyone help with this?
