Hello all, I’m working on my sons 99 Yamaha Warrior 350. When I pulled the plastic cover off left side of engine, I can see oil leak at the seal. I pulled the bolt out and then the starter boss(I guess that’s what it’s called?) I can see that the boss doesn’t make contact with the seal. Is there a spacer of some type that slides on to the boss, to make contact with the seal? This seal is held in place with a plate with 3 screws in it. This boss slides into the bearing in the stator. I have been to parts websites and I don’t see what I’m needing. Maybe it’s just the wrong seal?
  • Ajmboy changed the title to 1999 Yamaha Warrior 350 Oil leak, appears part missing
    • By Mhatayas
    • By fwsamm
