We have 2 Forum Moderator Positions Open!
Please use this thread to nominate fellow members of our community and/or pm me if you are interested in applying for the position. Please include the reason you think your nominee or yourself will be a good fit. Deadline for nominations and applications is April 5th.
Thank You.
Thank You.
Are the positions for all the forums or specific forums?
I'll nominate myself for the "We Ride Wimpy!" forum :goofy:
Tom D
I nominate stoopidbot for the Honda section of he forum if I can..he has grown in knowledge of motors and thing of that nature from experience in racing and such...for that mater..I nominate him for any position including mods or problems with your ATv.
I nominate
Wheeler0801
She is consistently Engaging the Forum members Which Keeps them coming back and Posting. She is Comfortable in the G-Spot Forum or in the Modify your Ride Forum. I believe that Those Qualities as well as more we probably dont know yet will be a Benefit to the site....
Oh yea,,,,And she is a Postwhore....So I think it would all work out:laugh:
I also nominate Stubidbot1 for pretty much the Same Reasons....However,, With him I think we would get a TWOFUR!!! He and his Maid Im sure would share the responsibilities...LMAO!! Seriously though,,,,He is on here sometimes more than I am, He is always checking out the Forums and giving insight whenever he can...This in itself will make him a Valuable asset to this Community....
In Closing,,,,Both of these people Deserve a Shot...If it wasnt for them....I wouldnt have the post count that I do....:biggrin::wink:
Thanks guys! TrailBlazer is right, I learned alot from my dad in my racing days but I have learned alot more from reading all these post. I like to read the problem and other peoples solutions. If I don't have an answer, I like to research it just fo my personal knowledge and to help a fellow rider. That means alot that you would think of me for the spot. Thanks again.
We have three nominations that I can see so far:
Wheeler0801
Stubidbot1
txduggan
Well of course I nominate my Stoopidbot! He LOVES riding and learing new stuff about quads and loves to share his knowledge as well. He's a great well-rounded guy! Gooooooooo Stoopidbot! :cheer::cheer::cheer::cheer::cheer:
    • By marcosphoto
    • By jpz
      Hello all,
      I am working on a MXU 270 and having the hardest time finding information. I recently saw a youtube video that claims the MXU 270 is mechanically the same as the Bruteforce 300. Can anyone confirm?
    • By Fowler175
      Hi everyone!  I am rebuilding my father's 2022 Sportsman 450HO that caught fire and wrecked all of the body and melted much of the wiring harness. I was able to source a used harness to splice in, but it's missing the wires and connectors going to the left side controls (Start/stop, headlight hi/lo & reverse overide). I haven't been able to find individual part #'s for these plugs/pigtails, Polaris only lists the entire harness for a huge amount $$$. At 72 yrs old, the last thing he needs is to spend all his money on a quad he's only had less than a year, lol. Does anyone know of the part #'s for these, or an aftermarket source?  Thanks!
    • By PKR
      I have had this machine running and put about 4 hours on it but it would not idle great. Would fluctuate between 700 & 2000 rpm and usually quit at the low rpm. Spark plug would carbon off and have to be cleaned. Throttled up nice and ran good in mid and high range. Machine then quit and wouldn't restart, couldn't get it to fire. Checked everything, had spark, gas, etc. Thought spark may be weak so ordered a new coil. Machine sat for 3 weeks waiting on new coil. Installed coil and machine fired right up. Idled nicely until it warmed up and then rpm's were all over the place. It quit after about 20 minutes and then would restart. If I let it sit for a few days it will start but won't idle.
      Fuel/air mixture screw does nothing, can be screwed out or in and no change in idle. Only way to keep it idling is to turn the throttle screw way in and have it revving over 2000 rpm.
      As this unit sat for close to 14 years I have replaced the pulse pump, carb, CDI, spark plug and now the coil.
      What am I missing? I have done all the ohms checks on the stator, pulse trigger, etc and they are all good. I've took the carb apart to ensure it was clean, reset the float to be leaner as plug was indicating it was running rich. Didn't make any difference. Don't know where to look next?
      Also can anyone tell me what these wires are for that come off the bottom of the carb (see pic).
      Thanks for the help
      PKR
    • By zane6969
      My trailblazer 250 has no power than randomly high revs and takes off after it gets warm. Any advice or suggestions?
