Started my 2006 Yamaha Kodiak 450 up recently (March 2019) and it didn't seem to idle good; the idle was erratic.  I turned off the fuel and the engine eventually speeded up to where the Revere red light started flashing before it ran out of fuel.  I changed the spark plug and no change.  Bought a new carb and installed and still not change.  Starts good and runs great when driving but the idle sometimes doesn't come down to where I can shift and other times it goes so slow that it stops running.  I have stabilizer in the fuel and have started several time in  the winter to keep the battery charge without problem but now that has changed.  I have 5700 miles on it but have maintained it good and it has been kept in the garage since I bought it new.  I have really loved this atv.
Any ideas on what the problem could be?
I'm about ready to take it to the dealer for troubleshooting but at a $110/hour I'm trying to solve the problem myself.
Thanks for any help or experiences any of you have.
Errol
  • Admin changed the title to 2006 Yamaha Kodiak 450 4X4 Erratic Idle
Why would you change the carb and not just clean it and reinstall ? The carb you put on was it a factory carburetor or aftermarket?
If the existing carburetor was just dirty due to crud buildup I would clean it up really well blow all orafices out and re install it.
Set the air fuel screw and the idle to the proper setting and go from there.
I do appreciate all of the comments.  I finally had the intake and exhaust valve adjustments tested and the intake valve was was way out of tolerance and after that was corrected and a little tweaking of the carburetor the ATV runs super now.  The technician told me that the intake valve (which had never been adjusted - 5270 miles) was the primary problem.
Thanks again to all.
    • By Trent Finnessey
    • By fwsamm
    • By DPDISXR4Ti
      Thanks...
