97 or 98 Yamaha 350 4x4 big bear
By Tim Keiper
By Thumpinhard25
By Panupong Pradchaphet
I have a Sportsman 450 HO and almost killed my self when loading it on my truck with ramps. It rolled off the top of the ramps and tailgate and nearly landed on me. I now want to winch the ATV in to the truck. My question is are the front side bed tiedowns in my 2011 RAM strong enough to winch to without distorting the hooks or sides of the bed?
By Tinkeringreg
By Kaz
