  • Ajmboy changed the title to Honda Sportrax Hubs From Recon?
the bolt pattern is the main issue- as far as I know, atv brands have the same bolt patterns among the models- so you couldnt take honda rims and put in on kawasaki....  But I would say yeah, go for it!  Worst case, you might have to buy some spacers to keep the rims from rubbing your brakes... dont know about that.
You'd have to  measure to be sure , but the hubs  may very well be interchangeable.  My guess is they most likely are if they are from similar  quad series. Hubs  from  a 250cc to  350cc bike in  either series are more likely to be a direct swap than  from a  250 and one with a much larger displacement.  More power would  call  for heavier axles  and hubs in most cases.
  • Like 3
    • By Coyote251
    • By J-Dub
      2001 250 Recon randomly shuts off but will immediately fire back up . Any thoughts
    • By huntindog
      TIA
    • By Sofaspud
    • By Am2007
      Hi everyone,
      owner manual
      service manual
      engine manual
