Yamaha Bear Tracker Starter Solenoid
By Tim Keiper
By Thumpinhard25
By Trent Finnessey
By Kaz
By Randomnumber73
I'm working on my uncles grizzly and it sparks once on initial cranking then no more after that. If I let off the start button then press the start button again it will spark once then stop sparking. I was wondering if anyone seen this issue before. Also I've never used forums before so sorry if this question is in the wrong location.
