I replaced the main , pilot and starter jets and it will not start , it wants to try and start , this is a fuel issue I think , what part of the carburetor might be plugged up if it will not start , any ideas
2008 Honda TRX450R
You have to take the carburetor off of the bike and completely tear it down. You will need a small piece of wire to clean every small port on the carburetor as well as a small can of air to blow out the carburetor ports while your cleaning it.   The part of the carburetor that’s probably jammed up is the float and fill needle inside the bowl. Not allowing fuel to get into the engine. Make sure you work on a clean surface and blow every small oraface out of the carburetor.
There is also a fuel air mixture screw on the carburetor before you take that out it would be best to count how many turns it is set at from a snug tight position so you put it right back where it was or close to it when your done.
    • By Trent Finnessey
    • By Tinkeringreg
    • By Dumass
    • By Arizona
    • By fwsamm
