Bought an '11 Vic with the 4.6L back in June and a few months back I tried to change out the plugs. All came out ok except for cyl 4 which only cranked out 1/4 turn. Had a shop take it out and they said they had to redo the threads. I've seen videos where you can remove a stuck plug by drilling into it somehow, but because this was in the 4 position and hard to get to I'm guessing they just power cranked it out. Not sure but I'm guessing those threads are compromised now.
Well, this past weekend that same plug blew out of cyl 4. Inspection reveals a coil and boot jammed up underneath the fuel rail and a plug that I fished out without any turning. When I go to install a new plug it just sits on top of the threads and turns without going in. So I guess what's happened is that the plug rotated most of the way out but when it got to the last couple threads the compression blew it out the rest of the way, and that it's just the top few threads in the hole that are damaged. Inspection of the plug reveals that most of the threads are intact except for the 2-3 that are closest to the element.
So my question is...should I try to fix this myself or just take it to a shop? Some kind of tap tool would probably fix it, but since it's the beginning threads that are boogered it'd probably have to start from the inside of the cylinder. I really don't have a clue as to how to approach this.
    • By gbanker
      Covers the following models:
      1985   Scrambler Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1986   Scrambler
      1986   Trail Boss
      1987   Trail Boss
      1987   Cyclone
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1987   Trail Boss 4x4
      1988   Trail Boss 2x4
      1988   Trail Boss 4x4
      1988   Trail Boss 250 RIES
      1989   Trail Boss
      1989   Trail Boss 2x4
      1989   Trail Boss 4x4
      1989   Big Boss 4x6
      1989   Big Boss 4x6
      1990   Trail Blazer
      1990   Trail Boss 250
      1990   Trail Boss 2x4
      1990   Trail Boss 2x4 350L
      1990   Trail Boss 4x4
      1990   Trail Boss 4x4 350L
      1990   Big Boss 4x6
      1991   Trail Blazer
      1991   Trail Boss 250
      1991   Trail Boss 2x4
      1991   Trail Boss 2x4 350L
      1991   Trail Boss 4x4
      1991   Trail Boss 4x4 350L
      1991   Big Boss 4x6
      1991   Big Boss 6x6
      1992   Trail Blazer
      1992   Trail Boss 250
      1992   Trail Boss 2x4
      1992   Trail Boss 2x4 350L
      1992   Trail Boss 4x4
      1992   Trail Boss 4x4 350L
      1992   Big Boss 4x6
      1992   Big Boss 6x6
      1993   2502x4
      1993   3502x4
      1993   2504x4
      1993   3504x4
      1993   Sportsman
      1993   2506x6
      1993   3506x6
      1993   Trail Boss
      1993   Trail Blazer
      1994   3002x4
      1994   4002x4
      1994   3004x4
      1994   4004x4
      1994   3006x6
      1994   4006x6
      1994   Trail Boss 2W
      1994   Trail Blazer 2W
      1994   Sportsman 4x4
      1994   Sport
      1995   3002x4
      1995   4002x4
      1995   3004x4
      1995   Xplorer4x4
      1995   4006x6
      1995   Trail Boss
      1995   Trail Blazer
      1995   Sportsman 4x4
      1995   Scrambler
      1995   Magnum 2x4
      1995   Magnum 4x4
      1995   Sport
