I was looking on Amazon for something and came across this prime video and I started watching it.
Surrounded By Beavers! - ATV Trail/Road Gone!..... BEAVERS!
Not bad but I've seen better on youtube with today's gopros. The one thing I like is that the guy is talking while riding and shooting the video. He must have a good mic in his helmet because it makes for more interesting time watching than just watching someone riding on trails. The guys narrating and explaining things. I looked on youtube and its there also...
How it became a prime video on amazon, I don't know...lol.
    • By pastorjeep
    • By marcosphoto
    • By KdlH
      Following on from this thread;
      I've finally got around to pulling the clutch cover off to have a look at the shifter ratchet mechanism. The screw holding the pinned star wheel has come loose and the wheel flops about. Unfortunately the keyway on the shifter cam has broken on both sides, I found both pieces.
      Anyone had this problem?
      The keyway on the cam "ramps" out, so I'm thinking of making a slightly longer key with a ramp ground into it. I'll put it back together with retaining compound. It may not work but I think it's worth a try.
    • By Jacksonbell
      I just went out to start my 2004 polaris sportsman 600 and nothing happened. It didnt have power to the dash and wouldn't turn over. I have no idea why, but it's not the battery because the winch still works. Can anyone help?
