So I'm trying to figure out the year of one of my Timberwolf's. I have 4.
2 are definitely 1993's, as I can read the serial number on those.
1 has to be close to a 93, as the back rack and lug width (156) are the same as the 93's.
The last one is killing me. Someone painted over the serial number.
Listed are the differences
Back rack is different. It goes through the plastics and will pivot on the rear attachment. Doesn't have the handles out the side, either.
Doesn't have the loops coming out of front plastics.
Foot rests are different.
Lug pattern is 110.
Everything I've read, says that the Timberwolf was produced from 92-98 and then changed name to Bear Tracker. Most parts are interchangeable through those years. Only change I found, was front brakes were upgraded to disk in 2001.
      CARFAX https://www.carfax.com
    • By marcosphoto
    • By gbanker
    • By DaleJAM
