2007 Prairie 360 4x4 Feedback or Suggestions
By PIYIRIO
By motox88
Anyone have bad experience with these clutch kits? Looking to get one for an 80s quad that I have.
By alexwv1863
I believe the Kawasaki is either an '03 or '04. Green automatic with shifter on the right side. Rear differential was bad, so I replaced it with another. The 4 wheeler rolled in neutral when I parked it in the shop to work on. Took old diff off and replaced it with another one. The diff I put on, turned before I put it on the bike. Once I put it on the bike, the rear end wouldn't move at all. It's like it's stuck in gear. Bike is still in neutral. I've tried rocking the bike while trying to put it in high, won't budge. Can anyone tell me of something to check or try? I haven't opened up the transmission case yet to see what's going on. What should I be looking for?
By Jameya
You guys are my last resort. Got a 2000 prairie 300. Brand new battery, neutral switch, aftermarket carb, spark plug, silenoid, key switch. Fuses are good. No neutral green light, will crank if cross the silenoid, but won’t start. No power at the ignition switch or regulator. I’m thinking cdi box or starter relay. Anyone have any suggestions?
By ankhearty
New member here hoping to get help on procedure to remove old non-working starter and install new one.
John in San Antonio
