    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
    • By Hooks300Bayou
      95 bayou 300 2wheel. This is my first four wheeler. The guy I bought it from showed me slight drip on his floor from a drain plug he recently retapped. I figured I could handle a small leak from a second hand machine. Well after a few times of riding it the bayou seems to be running low on oil. Now maybe this is normal operations as well so I refilled the oil. But the next day I notice my drip on the floor was slightly larger. I wanted to see this drain plug for myself so I took off the skid plate and found a pretty rough looking installed drain plug. It does have a small drop but also seemed to have an excessive gasket and maybe some grey looking “jb-weld” ish material around it. So that’s scary but I figure surely that’s not the only source since my floor spot Grew a bit. I went on to find recent moist around the head gasket for the top end. I’ve never seen it drip but it drips on the new starter the guy installed so it seems the head gasket leaks too. He did say he replaced that gasket when I inquired about the darken stains around that area of the motor. He said he replaced that gasket during. Ring replacement when the bayou was smoking. It no longer smokes by the way. So I continue on thinking well maybe I can do another top end gasket myself some day but still the oil on the floor suggests a more visible leak. I mean it’s not a lot but it grew as I mentioned. Then I find my what seems to be an awful thing. The pull cord and starter was replaced by the preavious owner and it appears there’s a busted area on the crankcase where the left side cover mounts to the L-case.I have not seen oil from there but that looks scary to me. Does this area hold oil? I wondered if it doenst maybe I’ll leave it be but if it does it’s probably the reason I lost some oil. I also found tonight oil on the rubber boot cover I think is for the drive shaft or something. Idk my first ride so I’m unsure of how to proceed. Especially with the case cracked like that. I don’t know how the engine works but if there is indeed oil there in the operation of things it seems like I must do a major engine over haul….. any insight would be so very helpful. I bought this for my daughter but I may have been bitten by going with such An older model.
      The year 2023 has brought exciting advancements in the world of UTVs (Utility Task Vehicles) and Side by Sides. These off-road vehicles have gained immense popularity due to their versatility and ability to navigate through rugged terrains. Let's explore some of the best UTVs and Side by Sides available in 2023.
      1. Polaris RZR Pro XP
      Polaris is a renowned name in the UTV industry, and the RZR Pro XP is a testament to their commitment to excellence. The 2023 model comes with a powerful 925cc ProStar engine that delivers impressive acceleration and top speeds. Its dynamic suspension system ensures a smooth ride, even over rough terrain. The RZR Pro XP is also equipped with advanced safety features, such as a reinforced frame and integrated roll cage, making it a top choice for thrill-seekers.
      2. Can-Am Maverick X3
      The Can-Am Maverick X3 is another impressive UTV that deserves recognition in 2023. This side by side offers exceptional performance with its turbocharged Rotax engine, providing exhilarating power and torque. The Maverick X3 features a robust suspension system that allows for aggressive off-roading, while its ergonomic design ensures driver and passenger comfort. With its cutting-edge technology and stylish design, the Can-Am Maverick X3 is a popular choice among UTV enthusiasts.
      3. Yamaha YXZ1000R
      Yamaha is a trusted name in the motorsports industry, and their YXZ1000R model continues to impress off-road enthusiasts. The 2023 version comes with a potent 998cc engine and a sequential manual transmission, providing precise control and quick gear changes. The YXZ1000R features Yamaha's industry-leading suspension system, allowing for exceptional handling and stability. With its sporty design and reliable performance, the Yamaha YXZ1000R is a top contender in the UTV market.
      4. Honda Talon 1000R
      Honda enters the UTV market with the Talon 1000R, a robust side by side designed for off-road adventures. Its 999cc parallel-twin engine delivers ample power, while the advanced suspension system ensures a comfortable and controlled ride. The Talon 1000R also features selectable drive modes, allowing drivers to adapt to different terrains and conditions. Honda's reputation for durability and reliability makes the Talon 1000R a compelling choice for UTV enthusiasts.
      5. Kawasaki Teryx KRX 1000
      Kawasaki introduces the Teryx KRX 1000, a UTV that excels in both performance and durability. Powered by a 999cc engine, the Teryx KRX 1000 delivers impressive torque and acceleration. Its sturdy frame and reinforced chassis allow for aggressive off-roading, while the advanced suspension system absorbs bumps and shocks. With its bold design and rugged capabilities, the Kawasaki Teryx KRX 1000 is a reliable companion for any off-road adventure.
      Conclusion
      As we venture into 2023, the UTV and Side by Side market continues to offer impressive options for off-road enthusiasts. The Polaris RZR Pro XP, Can-Am Maverick X3, Yamaha YXZ1000R, Honda Talon 1000R, and Kawasaki Teryx KRX 1000 stand out as some of the best choices available. These vehicles combine power, performance, and durability to provide an exhilarating and safe off-road experience. Whether you're a seasoned adventurer or a recreational rider, the 2023 UTVs and Side by Sides mentioned above are sure to deliver on all fronts.
      Do you agree? Comment below
    • By MikeyC85
      Hi guys -
      Working on my daughters Apache Tomahawk 50cc (GY6 engine I believe).
      Wouldn’t start, noticed that the stator Magneto wasn’t turning with the engine.
      Stripped it down fully expecting the woodruff key to be sheered/moved however this wasn’t  the case.
      It appears instead that the shaft itself isn’t engaging and/or is engaging intermittently as the engine turns over which is effecting spark timing.
      Any ideas on what could be the problem - I’m at a loss!!
