The only thing that would be left is the pump.   It may look ok but prob the culprit.
Have you checked the pump drive to the pump. There is a shaft that drives that pump. You need to pull the pump and crank the engine to make sure the shaft is turning.
    • By JMSwed
      Hi EVERYONE
      New member here
    • By mmikesell
      new to the forum saying Hello from arizonA
      im new to the forum where are good places to ride in az??
