I have a 98 bayou 300 2X4 . I had no issues and then pressure washed it and next time I got on it the clutch was slipping bad at high rpm’s. Oil level is good. Is it likely that it could be fine when parked and then immediately start slipping next time I jumped on it for it to be a worn clutch? Could water have gotten in somehow? I don’t have any noticeable leaks.
    • By Tinkeringreg
    • By Mhatayas
    • By neilroy87
    • By beast6228
      However, last night I was looking at the service manual and noticed that it mentioned that this atv has a crankcase breather tube as well. Mine does not have one, so I looked at Partzilla and looked at the parts diagram and sure enough, it's definitely supposed to have one. The problem however is, the service manual does not show how it hooks up and the parts diagram only shows the exploded view of the assembly. I just find that kind of strange, nowhere in the manual does it show how it connects. Does it have it connector, attach to a nipple? It just doesn't say and it bothers me that there is a hole there without anything attached to it.  If anyone has a Bayou 300 or Lakota 300 with an intact breather vent system and could possibly take some clear photos of it or know how it connects I would be very grateful. I have searched high and low and cannot find any information on it.
