I am new to forum, please bare with me. I have a 2000 Kodiak 400 that would not start, found timing had jumped 4 teeth, reset timing 'no luck', checked valve clearance all ok, .04 int / .08 exh, no luck. fire is excellent, did compression check (with gauges) compression is at "0". checked valves again still same. did leak down test found no leaks by intake nor by exhaust nor into crankcase. pulled head and gasket not blown, valves looked good (little carbon) pulled jug checked rings looked good. replaced with new rings, decarboned valves reinstalled top end reset timing and valves, still no compression. can any one please tell me what I am missing? by the way in past 19+ years have done many top ends never had this problem.
Is the piston moving when you crank it? Could be a bad crank
You should get something when it cranks over. 0 means the piston isn't moving.
Try to see if you get any compression from The top of the cylinder. Your lobes may be 180 out.
If everything else checks out. You may have a cracked head or the piston isn't correct
Have you checked the valve seals ?
Pull the top cover off and crank and see if you have air coming from valve seals.
I would disconnect the spark plug wire and put a jumper pack on it and crank the sh** out of it and feel for an air leak someplace.
Spray the sh** out of the engine with a good soapy water mix, I like to use what air conditioning mechanics use for leak checks.  It’s a real soapy mixture. An air bubble will show up someplace.
Im shocked that the timing has jumped like that and would result in the valve slamming into the piston thus cracking the top of the piston or bending a valve. But depends on how far out the timing really was when the jump happened.
I would really take a look again to see if the jug, piston or head is cracked as well as @06kfx440 has stated and that the piston is actually moving full rotations.
I'm curious as to what caused the timing chain to jump 4 teeth.  That's a lot for just a worn chain.
When you did a leakdown test, did you get at least 85%?
When you turn the motor over by hand, do the valves look like they're opening and closing at the right time?
Is the locating pin for the cam sprocket in good shape?
    • By Tim Keiper
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Trent Finnessey
    • By Tinkeringreg
