I just installed a new full system exhaust and a K&N filter on my '07 Arctic Cat DVX400.It uses a Mikuni brand carb.I installed the recommended 150 main jet before I started it.(Stock is 130)I started the engine and the head pipe turned orange hot.Is this a sign of too rich?Should I go to a lower size main jet or is there another adjustment/jet that needs changed?
actaually for most aftermarket exhaust on 4 strokes the head pipe will turn cherry red...ive heard this b4 not a big dealsigns of running rich or lean will be backfiring...
rich will backfire out the exhaust pipe and lean will backfire out of the carb/airbox...hope that helps.. if your bike isnt backfiring id say your fine...
I think I found out why it's turning colors.I didn't adjust the fuel mixture screw.On my quad;there's a cap I have to remove(damn you EPA lol)to be able to access the mixture screw.I was told by the exhaust manufacturer that I would only have to rejet the main(they never said anything about the mix screw).I sent a message to Dynojet and they said to get the most power I need to change the needle also.They've been MUCH more helpful than the manufacturer(they even have a Q&A forum-what a waste of my time that was!!).So I think I'm gonna order the Dynojet kit and maybe a couple more things while I'm at it.Thanks to all who replied...
    • By jhamrick75
    • By alain
      I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
      Any one would havd answers would be appreciated. Thanks
    • By wheeliewayne
      my  2012 big bear 400 is hard shifting  can anyone help me
    • Guest
      By Guest
      I have a 2022/23 Honda Rubicon, and was wondering if there is an exhaust deflector available.  I have a rear basket w/ chainsaw mounts, a winch on the rear, and a hitch.  When I am working at the rear of the quad, the exhaust puffs and hits us, while we work.  It is quite annoying and wound like to be able to direct the exhaust downward.  Is there anything that you know of that would work w/o creating any back pressure that might disrupt the engine?  I’ve been searching for something like this, but can only find ones for small engines and silencers that would interfere with the winch.
      dave
