Lift kit
By Winnem
Hello.
I've bought myself a Iron Baltic electric hydraulic plow lifter for my TGB, with a matching mounting kit. It was supposed to fit directly on my ATV. But I'm really not happy with the result. Had to cut off some of the cover under the atv, and still the angle didn't seem to be right in order to fasten the adapter on top. Also it touches the bumper and makes ugly marks.
Is there anyone here with experience, or know a good solution on this?
By Saskatchewaner
Anybody build/buy a lift table for working on your machines? I've got one of those little hydraulic motorcycle lifts but it just seems so tippy with a quad on it. And using jack stands with it means you're locked into a height.
By p5200
By dvs1961
By Earthmover
Hi I'm thinking of installing a body lift kit on my 02 F-250. Can any one tell me if there is any hidden costs involved for instance, do I need to extend my brake lines, steering collum transmission linkages or wiring
