Hi everyone. I need some help please. My quad ( shineray 250 2007 model) idles great and reves up but when i put in in gear it dies. I checked on youtube and they said it might be sticky clutch so i took it out and cleaned and put it back together but it still does the same. Could it be my air/fuel ratio?? Please help
Hi
I had an Eton 150 - CVT drive. The variator weights let the clutch engage too quickly, before the engine could develop power. By changing the weights the clutch engages later and - no stall.  I can't give credit to the source of the information that I found 'case I didn't save it.
First things first.doc
Thanx guys. Im busy with the air screw and its driving finally. But now theres another problem, when im driving in 1st and give it throttle it loses revs and want to die, but when i pull clutch it idles again???? What could be wrong??? I did clean the carb just now
Edited by Francois9314
Forgot something
@bdaigleyamaha open your clutch cover on the right hand side and take out the clutch and just wipe it off, when you put them back in dont mix them up. Put them back in the same order as the way you took it out. Then adjust your air screw on the bottom of your carb. I got my bike atleast to drive today but still not 100% when i want to give it gas so that i can go to 2nd gear it loses revs and want to die
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Mhatayas
    • By RussB
      Flywheel puller. Does anyone have the size as the part #529 036 049 is non existent
