So my cdi went out a month ago and Kawasaki is proud of that cdi. So wanting to know is there any way to bypass the system and but a different cdi in stator is a 3 phase and my trigger coil has 2 wires coming from it a blue one and a black with white strip. From the wiring diagram it shows that it goes in to the cdi. But what is that black with white strip. Is it ground or what
    • By Kawasakibayounospark
    • By neilroy87
      Adding to downloads library.
    • By dstoltey
      I have a 1992 Kawasaki Bayou, and every time I try to replace the fuse on the starter relay, it blows immediately. I have replaced the battery, and have exhausted all of my ideas. Any help is greatly appreciated!
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
