i was just wondering if you can run my 4 wheeler without the speedometer. i purchased it and the previous owner had broken off the sensor from the case during riding. well 250 dollars later for a new pinion gear and all new bearings and seals. i found out that the speedometer cable is on backorder. my plan is too remove the speed screw from the differential and cover the hole in the case. i was just wondering if that is connected to the hours meter as well?
    • By Mhatayas
    • By JMSwed
      Hi EVERYONE
      New member here
