4 hours ago, James Roscoe said:
2018 Ace 570
I just uploaded the factory service manual for the 2017-2019 Ace 500/570. It just has to be approved by admin first. Hope it helps you. Let me know if you need anything else
Edited by colin james
 Great help for 500 & 570 owners cause Manuals Publication raises Owner/Pilot's awareness on maintenance, .preventing  from costly repairs also as a mean to know vehicle limitations and proper ATV usage.Thanks and keep the good work ! Congratulations!!
  • 3 months later...
On 11/16/2019 at 10:20 AM, Mark G said:
thank you for this. hopefully now i can fix my lo battery warning on the display.
Did this issue get resolved?
6 hours ago, mrfreeze00 said:
thank you now maybe I can solve my electrical issue
And this issue.  What problem do you have?
well I have a 2017 sportsman 570 and it will not start... It started acting up randomly by not starting every time and now it will not start at all and I mean it will not turn over. I have power to everything just wont try to start.  I have checked the battery, starter, starter solenoid, most wiring from all 3 I have  jumped the solenoid and it will start so I think some where in the starter circuit I have a bad connection or wire that's why I need the wiring diagram to trace it down.
Starter switch?
  • 3 months later...
Can you give us more information  on. Check engine lighrl and no codes. What is the vehicle doing when the light is on. Also if the vehicle  has power steering. Any issues in the 4 wd and power steering could cause the Check engine  light to come on but not show any codes on the speedometer. Sometimes the only way to get the code is with a scan tool
  • 6 months later...
  • 4 months later...
I'm going to need this for some electrical references. 2019 570 SP EPS was left out in the rain and now I have zero power to anything. All fuses and relays test good. I'm not sure if these bikes have a secret fusible ground link or such in the harness.
  • 6 months later...
  • 2 years later...
    • By oxidized_black
    • By leecon
    • By KSIM
    • By KSIM
    • By KSIM
      View File 2018 CF-MOTO Z-Force CF1000US-2 service manual
      CF-MOTO Z-Force (CF1000US-2) (2018) service manual
      Submitter KSIM Submitted 03/19/2025 Category Other Brands UTV
