2009 Falcon 150 when cold, while start then stall, fuel runs out of air filter.  pull off diaphragm vacuum hose and "emission" hose, it will start and run.  after a few minutes warm up reconnect diaphragm vacuum hose engine will stay running/drive-able no issues, if "emission hose is reconnected to carb engine dies. carb has the elect choke on it.  a, I looking at a new carb or is the electric choke the culprit. carb has been disassembled and cleaned as this was the original issue but I didn't discover the hose removal trick until after....
    • By Tinkeringreg
    • By DPDISXR4Ti
      Thanks...
    • By kaidella
    • By Ethan7387
    • By Dsluder
