2008 Arctic Cat 500TRV Transmission noise
By BuckBilly
By Admin
Looking for Arctic Cat ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Arctic Cat ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Arctic Cat ATV manufacturer, however there are plenty of aftermarket Arctic Cat ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
CARFAX https://www.carfax.com
By TimothyLindblom
Hey all, I just picked up this Massimo UTV for $500. Got it home and replaced the starter solenoid which successfully got power to the starter. Starter spun but engine didn't turn over although the engine is not locked up. I thought it was a bad starter. Got a new starter put on today and it does the same thing. Pulled the clutch cover and saw the engine is trying to turn over but something is slipping and not letting it turn over. I figured it must be the gear on the engine that the starter turns. Where can I get that and can it be replaced without pulling the motor? And am I correct that that's the issue?
Thanks!
Short video attached below
By TimothyLindblom
Hi everyone, I’m new here and new to 4 wheelers. Just got a Yamaha bear tracker 250 and joined here to see if I could get some help.
The motor runs and it drives if it up on jackstands but if you get on and try to ride it, it starts to drive but then quits after a foot or two and dies out and won’t drive. The guy I got it from said he was running and using it shifting through all the gears great and he started it up the next day and it started this.
He told me he thought it was the U joint on the driveshaft. He said it was probably worn and needed to be replaced.
I just finished pulling the swing arm and rear end assembly to check out the U joint and there’s no play in it. It’s tight and not nearly enough play to be loose enough to not catch and go.
Any ideas on what it could actually be?
Timothy
