2013 honda Rancher 4X4 420ES.  I've replaced the solenoid, put on a brand new battery.  Checked battery with tester and hit the starter button.....12+v.  Took the starter off to check the brushes, took armature out to see if it damaged, the magnets came out of the case attached to the armature.  Is that normal?  I thought the magnets were glued to the casing.  I'm hoping that I don't have to buy ANOTHER starter.  Help, guys...... I need it.  I didn't go to UTI.
And that would prevent the starter from turning?  Also, I failed to mention, when I took the starter back off from seeing if the atv would start, the starter was hot to the touch.  That the reason?
I was thinking the starter would at least make noise when you hit the button.  On 2nd thought...it did.  There was a fair t click at the starter...then nothing when I touched the start button.  Anyway...we'll see......new starter will be here Friday.  Maybe they should get a better epoxy.  #gorillaglue
    • By Trent Finnessey
    • By Dumass
    • By Arizona
    • By carkivey3
