February Photo Contest - Vote! (Photos Below)
33 members have voted
By hfrost112
By marcosphoto
By JRW
Hey all, just posting to introduce and get ball rolling on the required number of posts to download a freakin manual. Recently picked up an 86 LT230S for $800, runs OK and kids having some fun on it so far, but it needs some work. I did an oil and filter change, other than a rough idle it's not bad, ordered some new front tires as those are thrashed, and getting left rear looked at as it has a slow leak and was somehow mounted backwards! Not sure how that happens and nobody noticed. Anyway, yeah sure I'll be posting more specific questions as I get into it, hope to just have it solid enough for kids to rip around at grandpas.
By huntindog
TIA
