I'm looking at both of these ATV's they are both in good condition.  I'll mainly be using them to pull around my utility trailer around my yard, as well as moving my boat in and out of my storage shed.  With both in the same condition what would make you buy one over the other?
1 minute ago, Darrinster said:
So far the 1987 Big Bear I bought was worth the money. Hope to have it for a long time.
I was going to say 1995 big bear which you have in the topic title because it's newer but you just updated the topic with a 1987 big bear. So it's a 1987?
My Big Bear is an 1987 I don't think they changed much.
I didn't update the title, I was looking at a 1995 big bear 350 or a 1987 honda 350D.  But now I found a 2000 yamaha Kodiak 400. For a little more than the big bear.  So I might go that route instead.
    • By Frank Angerano
    • By marcosphoto
      I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
    • By Daleon
      Do not know what else I need to attach the pull start to this machine. I have the pulley but nothing to attach it with. Could you help with what else I need. It's a 1999 Lakota 300
