my 2016 xlc500e keeps jumping out of gears, its very random in terms of gear or revs, can anyone shed some light on this as it seems to be getting worse. thank you in advance!!!!!
  • Admin changed the title to 2016 Suzuki Quadzilla xlc500e jumping out of gears
    • By Sportsman500guy
    • By bigd764
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
    • By Vlaco
      I want to replace the factory headlights with LED bulbs. Any idea a good one to get?
