Suzuki King Quad starting issue
By exalrod
Hi Everyone,
I recently purchased a 2005 50cc Polaris Predator for my granddaughter.
The wiring is a mess. most of it appears to be jumpered out (twisted together).
I installed a new carburetor. The gas tank was cracked so I found another one on ebay and got that installed. There is no air filter box. I ordered another one but, it has not arrived yet.
I did get it cranked with the kick start. But, it idles too fast and when you give it any throttle the motor dies off. The more throttle you give it the faster it dies off. It is very hard to start when it has not been running for a while. However, once it has warmed up, it starts on the first kick every time after that.
I am looking for a little assistance in getting it running better and also a wiring diagram and service manual if possible.
Thanks in advance....
By Need-help-with-quads
Can anyone help me?
By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By BuckBilly
By mga
