Hi Guys....brand new to this forum and Kodiak.
I have a 2008 Kodiak 450 4x4. I bought it used. It has 200 miles and 100 hours.
I tried to hook up a 15 gal. broadcast sprayer w/ a pump to the atv. It has two leads that I typically hook to the battery of my other atv and I've never had any issues in the past.
this was the first time I ever hooked this pump sprayer to this atv.
The atv started right up and I brought it from 1 barn to the other to hook up the sprayer. I shut it down and hooked up the two leads from the pump to the battery terminals via alligator clips. the atv was off at this time.
when I hooked up the leads, I heard a slight crackle/pop when I hooked up the battery terminal leads and there was a slight electrical smell. i thought it was just the crackle you get when getting a good connection to the terminals. i tested the pump, it worked and proceeded to start the atv.
No luck. All digital display items work and the atv will turn over, but it will not start. it sounds like there's no fire to it. it turns over strong.
I checked the choke and the auto kill switch thinking it got bumped.
I also checked the few fuses in the same compartment as the battery. all visually looked good.
is there another fuse I'm missing?
Anything else I should check?
My next step is to pull the plug, ground it and see if I got spark.....but I find it odd that not 5 minutes before it fired up just fine and it drove down from the other barn...and now it wont start after hooking up the sprayer.
ANY thoughts or input is much much appreciated!
Thanks!
JR
You say
"when I hooked up the leads, I heard a slight crackle/pop when I hooked up the battery terminal leads and there was a slight electrical smell. i thought it was just the crackle you get when getting a good connection to the terminals. i tested the pump, it worked and proceeded to start the atv. "
Just guessing was the pump turned on when you connected it? If turned off there should not have been and issue - something close get shorted?
Suggest you download the Shop Manual and check out the wiring diagram
First thought is that you had the terminals reversed and the second thought is the motor is seized on the pump sprayer. I used to have a 450 kodiak and loved it!
    • By Tim Keiper
    • By Panupong Pradchaphet
